I was out last weekend and was accelerating at WOT when it felt like something gave out and I could feel the sled kinda die down, didn't lose power but all the power wasn't there like when I took off. Any ideas on where I should start to look for problems? Also after it happen when I would get up in higher speeds I had a vibration from the sled, any ideas?
Give your track a complete and thorough look see. Maybe a chunk missing or broken rod. Post back with what you find.
helix
Also check drive axle/jack shaft bearings. If you are feeling the vibe through the running boards.
sandmann
- Dec 11, 2013
Look for chunks of missing drive belt
Sent from my SM-N910P using Tapatalk
Check your powervalve cables too,if one of them snapped that would explain the power loss,maybe not so much the vibration but definitely will make a difference.
