early 70's 433 clutch removal
sxr1000
minot ND
trying to get the clutch off a 72 yam 433, it has a special nut on the pto end that holds the fixed sheave on the splined crank, anyone know how to get it off? or have a special tool?
My fluid drives are a solid pulley and a normal nut ,, If the notches are exposed you can use a hemmer and punch ?? make an impression with plaster of the notches
and drill matching holes into a hob and insert pins into them . ?? if exposed , also a prewinding tool for bike suspensions .. not sure how to describe it..
Hope someone else adds to post... seem to use that nut in 72 and 73.. models.
Ron
