temp light 2001 SRX
Yamahasrx700
Channaho, Il.
I got a :short or open circuit" code on my SRX. Ijust went through the whole harness over the summer. There is no rub through atthe CDI/foot hold. Is there a systematic problem on this or should I go overthe entire harness again?
Did you check under the engine and under the handlebar pad? If it's an open at the sensor, it might just be the plug.
