Sleepnfast
On the 02' Vipers , once a problem is repaired that previously set a code does the ecm need to be cleared / reset ? Or does the system constantly monitor its systems and clear itself if no problems are present ?
It should clear the codes on its own. FYI-If there is more than one code the computer will flash the code of the lowest numbered code first, then flash the second and so forth. Once the code is
repaired it should no longer flash...nothing else required.
Sleepnfast
