88 phaser low end bog once warmed up?
upnorthbacon
Gaylord
After riding for about 15 min or so it bogs down low to where it won't even spin the track on takeoff. Clutches look OK and runs fantastic for the first little while. Always Idles good and once the rpms get up a bit it runs out good even when warm. Just got the sled and previous owner put new fuel pump, piston rings and fuel lines and in tank filter. It runs great other than takeoff but only after riding a while? I'm thinking its a motor issue but could something be going on with the clutches once they heat up?
just checked compression 110 on both cylinders warmed up and the plugs look perfect. Checked vent lines those all seem good.
