Hey
is there anyone out there who could help me with some Measures? I bought a 136" skid but did not get the correct cc with it. The geometry is a bit off because of that.... I need the cc between front and rear mounting bolt. Thanx/d
pinboy122
If I get over to the shop I can get it for you tomorrow
Thanx man! I really appreciate it
pinboy122
ok prankster, I found from the front bolt in the footwell to the idler shaft to be 15 1/2". from the front footwell to the rear mount bolt I got 33 1/2". The measurement might not be perfect exact but real close.it was a little hard to get exact on the rear mount because its under the footrest while the front is in the side of the tunnel above it. hope this helps. these measurments were taken from a 95 vmax600 dx
