Srx power valves
wooddoctor
Elburn, Illinois
Does anyone repair power valves for 98 srx 700? I have pull through on one, checking others. Also when removing valve for cleaning I know you take off the 4 bolts and the entire valve and everything comes out. My question is should I loosen all cables first? Also what about disconnecting cable from valve? Will there be enough slack in cable to pull out from back side so cable can slide off of back side of valve? Or do the other 2 bolts and cover need to be removed to get cable off valve for cleaning? Any help will be appreciated.
