sxr6vt
Does anyone know what the stock needle size is for a 2000 sxr 600?
Or where I can start looking to find out?
I have bender pipes, bender clutch kit. Been having a hard time getting the right piston wash and plug color, at midrange. Half throttle test show white plugs and temps as high as 1270 on 0 degree days. I have main jets very rich right now to help with the midrange lean problem.
SXRYAN
I have a 2001 SXR 600 and I'm running bender pipes with the needle in the stock pos and 140 mains never had a problem I am running slightly bigger pilots though 45's Also might want to try changing your air jet from a 1 to a .8
sxr6vt
Thanks sxryan, I'll try my dealer in the morn hopefully they have in stock. I'm ready to try anything.
Any other changes you had to make?
What kind of mpg are you getting?
