Can anyone tell me what tool is best for compressing primary while it is still in sled?
I am tired of pulling it off to adjust weights. The only one I have seen is a Snow-Stuff brand is that the only one.If so I think I can make one pretty quick.
Like this.... I have something similar. Id make one if you have the capability.
http://mcbperformance.com/i-8036466-sno-stuff-clutch-compression-tool.html
Yes that's the one I found. It looks like it must go directly in the spring and pry against the clutch,is that correct?
What I do is install 3 longer bolts into the cover. I tighten them down to compress the spring enough to install the factory bolts.
Put the hook between the spider and pry towards the motor, then hold as you put the little channel on to hold in place.
Yep,
