8bu-10
fastsrx
onalaska,wi
Putting 8bu-10s in 98 srx 600. Primary has 15mm rollers, secondary has maxx roller with a 52/42 helix. How would you guys set it up. Any help would be great.
i don,t know what will happen with a roller secondary. i would use your stock secondary. i have tested these with great results in the srx 700. use around 50/40 cam, set them up around 50 grams. these weight fly. 3:16 (yammie tony)
Tried the weights today. Got alittle snow last night but farmers field is alittle rough. Had weights at 52.7 with 2.9 in both holes. engage 4200. wot 78-7900. On hard rpm would drop to 6000, then back to 7800. Felt like secondary upshifting to fast with roller sec. Remove 2.9 from outer & tighten sec spring to 80. now at wot 8200 & stays there, could only get to 75 mph because of short field. RPM does not drop back like before. need to try shims in primary and maybe stock secondary
