jhanna454
Hi guys I got a 2001 SRX and I'm having trouble adjusting the rear suspension so that the whole track lays flat on the ground. As it sits now the rear of the track sits up off the ground about a half an inch, while the rest of the track tapers down to touch the ground. Any ideas on how to correct this? It is a stock suspension. Thanks
snomofo
VIP Lifetime Member
Usually means someone has the limiter straps out a ways or other more pressing stuff. Has the skid been gone through for all the fixes? Is the sled new to you?
jhanna454
Thanks! That is probably it. The sled is new to me but had a broken rear rail and front suspension arm. So I just got it back together after replacing those parts and I did notice the limiter straps were set to a longer length on the new suspension arm. Didn't think that would affect it but i'm not the greatest when it comes to suspensions.
RB2001SRX700
Lifetime Member
Those skids will not sit totally flat. You can tighten up the front straps but still wont lay flat. Just the way the are made.
