J
jaydougempire
Guest
Just put about 23 litres of 87 in the viper by accident!! When I realized, I stopped and topped it off with about 11 litres of premium. My gas station is apparently ethanol free...am I going to blow up if I run this gas...? octane booster maybe? On my way up north for a long ride today don't want to have a problem...if I can avoid siphoning it out that would be awesome
Not sure what your premium is but if it is 93 and you add some boost(for sure), don't run it hard until you get that gas ran out you should be fine.
I run boost and premium whenever I can, in everything even a old fan cooled doo. But have been in the middle of nowhere and had to put the low
octane in with no choice, I always have boost in my trunk. It would be better to get it out ...put it in you truck.
Backwoods M Max
If you don't have to ride it far I'd get it home and drain it. Those shaker siphon hoses will drain a tank just about dry. If you pick up the back and put one ski on a 4x4 to make a low spot there will be less than a gallon left.
J
jaydougempire
Guest
Thanks guys
maybz
I always try to run premium in my 2004, but my buddy never has in his 2003 and he has never had a problem
sgauthier
You should not have a problem, just don't hold it to the bar for endless miles. When you get a chance just add premium. Done this many times on my srx and my apex.
+1 ^^^
You'll be fine, just run it.
just run it. only time brothers 02 viper and dads 05 sxventure ever see high test is at the end of the season. runs better on it for us but we are trail riders so not too often on long wot pulls.
