Srx 700 fuel filter
joejammer
I had my srx out for first time this season it ran good. Idle, mid range, top end all seemed fine. Tryed to take it out today it took 20 or so pulls to fire it and ran like garbage. I cleaned the carbs in November. So it looks like i picked up some crap in the carbs. Has anyone used a fuel filter on this machine? I was thinking of k+n inline before the pump
I got the premium fuel from Pioneer. I drained fuel from the tank and carbs last spring. When i cleaned the carbs they were spotless
I had a similar problem on mine a long time ago. While on a long "guys" trip, my pilots plugged 2 - 3 times a day. Every time I'd clean them, while everyone else was in the bar, I'd find my pilots plugged with a white gunk that I could only assume the stock in tank filter dissintagrated. After that, I've run a large clear and inline filter. Took all if 2 min. to install and haven't had that problem since.
I think I will do the same. I gotta clean the carbs but it's cold in the garage
Thanks everyone it was water in the fuel carbs are cleaned tank pumped dry. Just need Some good premium fuel.
No you don't, it comes out the gas fill hole. Use a coat hanger to fish it out. The hose is just long enough that you can change the filter.
