getting a bit of spark knock or ping sound who knows how to get rid of it!!
700srxrob
petawawa
i here it is common that the srx does this but will running say 2 litres of race fuel mixed in with my supreme solve this issue ?
I can't image that ping/detonation could be heard on a sled as it should only happen at WOT, and sleds aren't the quietest vehicle for listening for it. If your concerned, verify jetting, piston wash, and ohm out the caps.
Could you be hearing something else?
I agree, it's not detonation if it only does it at idle. The motor is at minimum timing advance down that low in rpm. It's got to be something else rattling around somewhere. Good luck in the search
