newbiebravo
98 bravo Lt..dual fuel tank switch-over..is the fuel valve left side engine a shut off valve or a switch over to secondary tank?Or does secondary tank automatically kick in when primary goes empty?
newbiebravo
yeah I get it..shoulda posted in vintage
moved for you. I personally do not know.
newbiebravo
tks.maim..will just switch the valve..its either a shut-off or its not..good toknow before im 10 miles from nowhere.lol
PZ 1
- Mar 12, 2005
There should be only one fuel tank...the other one is oil. Do not put gas in it - keep oil in it.
YooperWoods
Some did come with a second fuel tank. A buddy of mine has one with two tanks.
smashed yams
I've got a 96 bravo lt and the fuel switches from one tank to the other via that manual switch, I believe it also will shut off fuel to the carb.
could always hook it up like a tour buddy and bypass the switch totally.
newbiebravo
3 tanks..2 are fuel..one is oil..sled is oil injected
newbiebravo
mystery solved..switch is a transfer switch,thanks for the input
