J
jaydougempire
Guest
Wanting to see how guys are mounting their digitron gauges. Got one coming for my viper...im thinking handle bars but wanted to see what the clever folks on TY are doing on their vipers and srx sleds.
Happy sledding
Happy sledding
Egt
I placed mine right on the handle bars. I had some left over clamps for mounting a windshield on a motorcycle. I just used some L brackets. Sliced some slits on my pad and installed the pad then mounted the guage to the L brackets. Sits up nice and visible. This is the only picture I have. I have a cover on it here that use when I leave out.
Those things are neat but too expensive for me, for now.
J
jaydougempire
Guest
Made an aluminum air box up for a guy for a turbo rx1. He put the four stroke turbo setup in his sxr! Way cool...he had digatrons on his sxr when it was still a 700 and has no use for them now so he's giving it to me as payment!
"Will work for sled parts"
SRXBOY
This worked well for me.
I used a variflow from pretty much day one and didnt want to take a chance. After I got the gauges installed there were lots of runs across the lake with plug checking and jetting. When I got the plug color to where I wanted it the corresponding temperature on the gauge gave me my max temperature I would run it at.
J
jaydougempire
Guest
Looks awesome! How did you see your tack and speedo? hard to tell from the picture if they are covered...
SRXBOY
Speedo is easy to see I use the tack on the gauges
SRXBOY
J
jaydougempire
Guest
Which power source did to tap into? Doing some electrical work here now. Don't have the new toys yet but Figure I'll run a wire for the egt while I'm at it.
