Yamaha RedHead 700 Triple Pre-Mix Question?
newbb
WI
Hi guys, I have a really fast 97 Yamaha sx 700 Drag sled that is setup for Premix at 40:1 ratio.
The oil pump is removed and a block off plate in its place.
My question is concerning the two little nipples that have oil lines coming off them on the bottom of the motor.
Without the oil pump what is the best way to make sure the two bottom oil points get adequate oil?
(Right now both those lines are routed up by the cylinder head and just connected to eachother with some thicker oil put in the lines.....is this the ideal way?
