Reverse case question
gbic1
Peotone Illinois
A friend threw a pick through his front heat exchanger on his 99 Deluxe. He bought a 97 600 Chassis and we are swapping his 700 red head and reverse and electric start to to this sled. I tore the outer cover and removed the gears on the non reverse sled . It appears the back cover has the hole for the idler gear Do i need to swap the rear cover? It is not an issue bit if I dont have t mess with the parking brake it would tickle me. I hate that thing.
all the chaincases are the same so to add the reverse you only need the cover and all the guts will go right in.
