98 vmax 600 twin- What is the sensor on the throttle linkage? The wires were cut off of the original carbs that came on my sled and looks like it was just jumped out coming off the main harness. I got replacement carbs that have the sensor/wires still on it, should I plug them back in or leave it jumped? Thanks
staggs65
that is for the TORS (throttle over ride system (or something like that)). You want that hooked up. that prevents your sled from running away on you wide open.
staggs65
If you have issues with it acting like you hit a rev limiter at 3000 rpms after you hook it up you likely have the throttle cable too tight.
