Heat Exchanger Fix?
NewfieGuy
Newfoundland
Hey,
Discovered yesterday that I have a hole in my right side heat exchanger. Looks like I hit a rock at some point. Just wondering if JB Weld would be a good temporary fix to tie me over until the end of the season? All info is appreciated.
Kirk
If you know someone with a tig welder that works good. I have welded them for people before.
My neighbor has a welder but he will be gone for the next month and that would cause me to miss the best part of our snowmobiling season. Are aluminum soldering rods the same as the Dura Fix stuff? Is aluminum soldering a good fix for this?
Take it to a fab shop and get it welded. Shouldn't cost you more than 40 or 50 bucks
flush with hot water and then use brake clean and compressed air to clean the area, preheat it up with map gas before trying to weld it to evaporate the water and make it easier to weld the aluminum, you can weld them pretty easily if clean it will hold with zero issues.
Make sure you pressure test it after its welded to insure no leaks!
they are pretty easy to change and not very pricey.i just tried welding mine with tig it had a hole on the very top extending to a crack between foot board and heat exchanger was impossible to weld I changed it out lots of rivets but not to bad to change.i tried jb weld before does not work it will for awhile but left me sitting on a trail overheated not fun .there are plenty of them for sale here on totallyamaha.
