hey guys just wondering if this could be a pilot jet issue , i have read a lot about the screens in the carbs that need to be cleaned but I have no idea what screens any recommended links to the best top to bottom carb cleaning ?
Screens are under the float needle. Small phillips screw. Remove the screw and then you can pull the brass piece out and check screen.
YAMMIEGOD3:16
check and clean pilots before you do anything. 3:16 (yammie tony)
Search Mr. Viper's carb clean 101
Check the link for a good pic of the inlet screen and its location.
http://www.totallyamaha.net/forums/threads/68597-Just-a-heads-up?p=453076#post453076
A couple of bucks
http://www.totallyamaha.net/forums/threads/68597-Just-a-heads-up?highlight=Daman+screeni have read a lot about the screens in the carbs that need to be cleaned
jinx!
thnx guys i should have looked harder i found mr vipers carb cleaning 101 , I'm pretty sure my dog could clean the carbs after after reading that ! lol
thnx guys that was helpful gonna go clean them now !!!
Those pins that hold the floats in are not wanting come out any tips without breaking the carb casing that holds the pins ?
I use a spring loaded punch,set it at weakest setting..works very good for removing and re installing them pins.I just removed the pins on carbs for my SRX about 3 weeks back..better then taking a small nail setter and hammer..
X2 - If you don't have a push punch, just support the float pin tower closest to your hammer on a bench and lightly tap on the pin. I use needle nose pliers with one tip of the plier on the pin and the other tip on the tower and squeeze.
The push punch works well. Place a rag on the exit end to catch the pin.
Awsome thanks is there any links to setting the float hight
bluewho
I just went thru this with my 01 after cleaning carbs that were clean already it would not stay on 3 cyl .Changed cold plug no difference took it out for a spin and got the crankcase cleared out and it runs fine now.
