panterahead79
hey yammiheads,
I have a 99 srx 600. Have any of you found an alternative to the 88T-26240-85-BK hand warmer? I would like to just replace the one grip everything works fine. except the one grip got tore so it is no longer working. I can't seem to find the grip in stock any where says it was discontinued part.
thanks,
ph
thanks,
ph
www.cycleshackms.com/yamaha-hot-grips-d1
I saw 1 here for $26.49
About 1/3 way down page.
Hope this helps.
88T-26240-85-BK COLOR: Black
MARKETING COLOR: Black
DESCRIPTION: Individual Stock Replacement Grip, Grip only (no mounting hardware).
Hope this helps.
john 89 phazer
I'm in the same situation. I've got a 98 Venture and the end of the grip is torn off, the wires are sticking out. I would like to replace 88T-26240-85-BK but they are tough to find. I found one on EBAY at $95 I like these grips and the other one is perfect. I will probably by this and stay original. Thoughts on this versus replacing both sides with a new system?
EVOVII_SWE
Could the 8DN-26240-00-00 from the 2000 on SRX700 be an alternative? They are still available it seems. I guess they are blue so both would need to be replaced. Then it's the question if they are the same wattage and so I guess.
that belt has been up dated but still works well.
roudyroy1
are they different resistance? why not just update
I have a set of the 88t handgrips used but still good.
phidelt479
still have these?
do you still have these warmers? If so, PM me. I am interested in them.
