wisc93ex570-2guy
Hi guys do 700 redheads normally run fat or burbley for a bit when cold? I've had the carbs off and checked cleaned jets nozzles etc floats are all same from bowl base to float top viton needles not worn any other thoughts? Thanks
yep always have, nature of the beast
wisc93ex570-2guy
Thanks I'll get it out to a lake and take her for a rip soon plugs look ok I should get it in for a carb synch oil pump check when I pulled the bowls there was dark fuel in there.
super1c
Super Moderator
I think this is what the reed stopper notch or reed spacers helped with if i remember right. Any confirmation on this?
roudyroy1
the red head engines have a mid range burble in them and its amplified when it cold. let her warm up and get a set of reed spacersand i think dropping the needle a bit helps, it will almost be gone.
wisc93ex570-2guy
Thanks where can I get reed spacers and how many clips from needle top? Thanks
roudyroy1
Royal distributing or make your own, it's not too hard. I can't remember on the needles. I think Turk recommended something in the tech section in the clutching pages for needles and jetting
