How to adjust the oil cable?
SRXBOY
Edmonton Alberta
Hello
I have a 98 MSRX which i just cleaned the carbs on. I put it back together and the oil cable seems to be very loose. When I let go of the throttle the cable is kind of bunched up behind the throttle lever. When i pull on the throttle it opens quite far before the cable tightens up. I have looked on the site and cannot find a post on how to adjust the cable.
The only other issue I have is after I cleaned the carbs last year I could smell oil burning when ever we stopped for a brake from riding and I turned it off.
Anyone know a link to how to set the oil cable or know how to do it? I have read settings between 20 and 22 mm but not sure where to measure this.
I would prefer not to ride it for a tank of gas and see how much oil I used I would rather adjust it then do that test.
Thanks in advance
John
