sleddog1
Has anyone tried adjusting the fuel pilot screw on the bottom of the carb without taking the carbs off? If I can get away with adjusting them without taking the whole carb rail off ,that would save some hassel. SX 700 the screws are directly on the bottom ,I just want to lean it out a bit.
edunn69
Remote adjusters are about the only way to reach them while installed. There's a write up on how to make your own set on here, I think it's in the text section.
here you go: http://www.totallyamaha.com/snowmobiles/aaTECH/rules.htm
