Ignition coil question
Check the part numbers for both. Parts listings are here on the home page.
Do they bolt to the motor or the air box, I know on my 02 SXR the coils bolt to the motor and are the same one used n a SRX.
So there is the answer, the coils will not work, I think the 01 and up have the different stator for the 300 watt system, I also have it it my 02 sxr. Same coils. You need the same ones that you have now I think.
