LGUNN
I have a mid to full throttle bog happening regularly on my enticer. At its worst the engine shut down and when I looked at the carb, it had pulled away from the intake manifold. It seems like it is being restricted of air in some way putting strain on the carb boot. I have checked the air box, coil, fuel. Idles and runs well at low throttle. Puzzled....
Thanks,
Thanks,
Throttle Junkie35
Exhaust plugged??
when was the primary last cleaned and the spring replaced? I chased a bog for 2 years from one of those. have you tried cleaning the carb too as the air circuits seem to like to gather crud. there are 2 on that carb so be careful.
