Using a Viper Fuel pump on my SXR (NOT AN SRX)
tcdesignguy
Lakeville MN
The vipers and SRX's use a fuel pump that has an extra hose that loops over the top of the pump.
What is the function of this hose and is it ok to use this pump on my SXR. I am intermittently loosing top end and I want to test that by swapping pumps.
Also picked up a used stator in case that could be causing it.
Thanks!
Steve
Thanks!
Steve
You can use the SRX/Viper pumps on the 600 + 700 Red head triples.
The extra hose is a bypass circuit built into the pump.
