Led Headlight help
deeperthebetter
omaha, ne.
Was wanting to install a Ridgid Led Driving Light on my 99MM. Its 12vDC, 1.45 amp draw, how can I make this work. I originally thought I could just use the original headlight wiring, now im not sure if that will work or not? I have a BR Tech hood so the original headlight is gone, wiring is still there. So can I use the original headlight wiring or is there another power source that is suitable?
Headlight power is AC and wont work. I actually started a thread asking same question and ended up giving up on it. Im sure theres a way though.
To run the LED kits that are on flee bay, rocks, and britelights are all plug and play. No conversion needed, comes prewired with its own ballest ect. I have yet to see just a bulb big enough to light up the trail that won't melt the housing.
Kits are nice and all but i/we already own the led pods that wed like to use.
Does the ac dc thing really matter its only 12 volts. In the cree lights you are powering up the ballast only that powers up the led. Also if you use a rectifier wouldn't you get pulsating DC voltage. I am going to email cree and see what they I will let you guys know.
