i took my power valves out tonight and noticed i have one pull threw and one broken cable and one badly frayed , i looked in my tickle trunk and noticed i have 3 power valve cables that are the same as mine other than being about 5 inches longer what are they off of? no way of using them on my srx?
they are probably from a Viper.I purchased 6 of them from a member years back because cheaper then new. Sure there are a little longer,but that doesn't effect anything except that they are longer,valves still work,servo works..all adjusted properly..go for it..
Being longer they may want to lay closer to the exhaust, check the routing and/or protect them accordingly.
Where is your servo motor located? You have 1998 listed under your name, and the cables are really short for that year with the servo mounted in front of the airbox. All other years + Viper have the servo mounted next to the airbox above the secondary clutch, and the cables are longer of course, by much more than 5". Also, your SRX has 2 different length cables, I believe it's 1 longer and 2 are shorter, but I could have that backwards. The difference in them is about 3" depending on how you measure.
didn't see you have a 98 SRX,those cables are way shorter.But you may be able to tie the cables so they won`t fall towards exhaust..
