kingjames2330
I just changed my right heat exchanger a week or 2 ago and it's blinking the warning and check engine light looked up the code it's for coolant sensor I've been watching it and it dosent seem to be air locked bc it dose use very little anti freeze and the motor isn't running hot at all. Any one have any ideas
Toxic hunter
Toxic hunter
If it's doing it all the time, check the wires at the temp sensor. They are known to break right at the connector.
kingjames2330
Okay where might that be to be exact
Toxic hunter
Toxic hunter
What sled? either the water rail or the head
kingjames2330
02 sx viper
Toxic hunter
Toxic hunter
Viper is mounted on the back right corner of the head
kingjames2330
Looks to be the prob
Toxic hunter
Toxic hunter
Here's some info on the connector if you need to replace or repair it:
http://www.totallyamaha.net/forums/threads/98292-Thermosensor-connector
