jdub-viper 700
any help would be every appreciated thanks, John
roudyroy1
after idling in cold weather when warming up my sled always leaves a oil mark and smokes until it clears out all the oil and gas from warming up. is your choke frozen open? i experienced that last weekend in -35c. once i got it open it didn't close all the way until i pushed on the end of the rod near the clutch. if your oil pump is gone you will be using like a tank of oil to a tank of gas. monitor it and find out.
Also check the oil cable, make sure it didn't get pulled apart.
jdub-viper 700
its never left oil even when really cold out and the smoke is much worse now than ever it wasn't that cold today either, it doesn't have the throttle response like normal either and it idles really low...it kind of sounds like its dead. i think my choke is stuck open but ill check the oil cable and the choke, thanks for the help guys!
