Sleepnfast
What should the proper casting numbers be on an 02 700 srx?
Sleepnfast
And head #'s
98-99 srx have 8dn-00 on them both on sides of cylinders and on heads. 2000-02 srx have 8dn10 on the sides of cylinders and on heads
Sleepnfast
Awesome thanks
Sleepnfast
Do they have different specs ?
yes, they are differnt porting specs and the heads are differnt volumes so it will change the compression ratio as well, they dont interchange unless you use all 3 cyl and heads as a set.
Sleepnfast
Again thank you
