Yamaman700srx
Hi I have a friend that has a 78 pantera and he seen my exciter 440 with the 85 Phazer skid I installed so now he would like to see if he can get a newer skid to install in his sled. Has anyone here ever done one up or know of someone that has? I heard a zr skid might work but I can't find any specs on it. If you have info we would greatly appreciate it thanks.
Throttle Junkie35
You would most likely have to change the track and drivers to accomodate a newer skid in the Pantera. I believe the Pantera is a runs a track that is 16" wide and has 7" slide centers. Newer skids and tracks are 9" slide centers. Also, I believe you would have to change the drivers because not only would the center be off, the pitch is different than the common 2.52.
Just one thing to do. Experiment
Yamaman700srx
Thanks guys for your info.
