nelsonhouse
Are the srx 600 and 700 crank cases the same ?
will the srx700 jugs bolt onto the srx600 crank case?
yes, zero differance as long as all the parts are 98-99 years
nelsonhouse
so a 780 bigbore kit will bolt right on to the 600 srx.
i have a chance to buy both for cheap from different people.
i have been thinking about buying an srx for awhile.
yes, you can bolt a 780 kit onto a srx600 bottomend. The engine case and crankshaft are the same on the 600 and 700 srx in 98-99, the stator all the same everything the same until you get to the cylinders,pistons and powervalves, heads but thats because its a 600 so it was smaller bore. The 700 stuff will bolt right on as long as you use the whole topend.
780 with the hotter timing in the 600 box makes for a fun motor package
