Dylanm121
Hello i purchased a 2002 sx viper that was blown up and torn apart. I got it all back together except the fuel pump lines. I have the three lines going to the carbs. then on the right side of the pump there is a little brass fitting and a bigger aluminum fitting below it. what lines go to these fittings? pictures and help would be greatly appreciated thanks in advance!!!
Youllbe2nd
That pump has a pulse line coming from the crank case and this should be your large fitting. As the crank turns it sends an air pulse through this line which gives you fuel pressure. There's 3 outlets for your carbs, then there's an oil line (small fitting) from your oil pump.
Dylanm121
okay thank you! now the oil line coming from the oil tank connects to the big fitting on the oil pump correct? and the one crank case line from the bottom i dont know where that one goes
