sleavitt
Hi Folks,
Been doing a lot of research on here about the Mega Power Heads and I can't find the torque specs or torquing pattern. Of course Mega Power is all done so I can't find specs online either.....anybody have this info??
Thanks!!!
Thanks!!!
same as stock tighten down in criss cross pattern to 9.5ft lbs.
add: be sure to make sure the little o-rings have a smear of lube on them so they will not tear on the bolt washers
sleavitt
Awesome....thanks for the info MrViper.....you kick *** by the way!!!
Mac
macs right just make it 20ft lbs as I was thinking srx where there is no headgasket to compress but still oil the o-rings.
