Swap Plug wires
Dozerike
Ny
I see lots of discussion about swapping plug wires on some of these Yamaha because they all fire at the same time.
Dose the 2004 Venom fall into this group? Can i swap wire for 2 and 3 with no adverse effects?
Not familiar with the 04 Venom BUT I don't think so. The older models with a single head light bulb you can, newer models with dual bulb/hotter ignition system (3D ignition) have firing orders. You would have to move coil/plug wire assembly to other cylinder.
