trep_power
Hello everyone !
I have a Vmax 136'' 1,25'' 700 1998
The skid is from a summit 550F 2002 but it's not me than install it... it is the owner before me.
I got an skidoo rex xm bench too with homemade braket.
It got some flex ski from ski-doo too. I would like to up the front but I don't know how ?
Putting some longer front shock? The OEM are like 17'' long...
It is 8 tooth drive
and I would like to know if it could be good to gear it down ?
Like putting 39-20 ... it have a reverse so 39.
Eventually I would like to do this clutch setup from the tuning tech :
97-99 SX 700 trail
51/43 Helix, stock weights w/4.5g rivet in 1st hole and 3.1g in tip, 2-3 engagement shims, stock springs, 1 or 2 layers removed from head gasket and 22/40 gearing. Jetting: 142.5 mains
I do like 50/50 trail and backcountry
Here is some picture :
It is 8 tooth drive
97-99 SX 700 trail
brethren
Frankenyami....coool
super1c
Super Moderator
You are already geared down with running 8tooth drivers
trep_power
What about gettong the font higher ?? Viper shock ?? why does the viper make it higher if they are both 17'' ?
tcdesignguy
To start with...Spindles are taller on the viper.
