T.o.r.s. Question
OLDCAT
Need Help!!! This Weekend Tors Was Acting Up...i Bypassed It But What Do I Need To Order To Fix It? Thanks! Part Number? Or If Any Body Has A Used One I Will Buy It....
if you bypassed them at the carburator the switch may be dirty. You can try spraying cleaner in the switch. The part number for the switch if you have the tripple carbs is 87S-8259A-00-00. This is a common switch for SX models.
Check on the TY home page for the online yamaha parts to verify if your switch is tha same. Look under the carburator and you will find one called carb switch. This is the T.O.R.S.
Hey there oldcat , back the tors switch all the way out , hook your wires back up then turn the switch back down until you see it just touches the base. that should reset it .....if this does not make sence pm me your phone # and ill give ya call ..
