Question on o-ring spacers for drive/jack shafts
ReaperSRX
New Liskeard, Ontario
When you re-assemble the drive/jackshafts do you install the spacers with the O-rings on the shafts or do you install them on the back side of the chase case in the oil seals? Thanks.....
I always put them on the shafts first. Putting just a little grease on the o-rings helps hold them in place and a little oil in the seals makes everything slide right together.
