kinger
Hey guys, I ride with a 05 vector and RX-1 and I don't like how my viper rear end looks compared to them. I would like to get it to look like a viper with a 136" conversion but without the conversion. Is there anyway to modifiy the rear to make it look a little more aggressive and see more track? Thanks
Steven DeMarco
- Feb 16, 2004
throw an expert x rear suspension in it. mine sits 3" higher than stock at it's lowest setting and can be adjusted almost 3 inches higher. you can set it so high that you are constantly sliding into the tank. if you like that sort of thing??
kinger
Yeah I don't want to throw that sort of cash in the sled. Its just a viper that I paid less then $4K for and I want something that maybe relocates the mudflap and exposes more of the track. Does that exist?
98srx6
So your just trying to make your sled look more aggresive?
kinger
Yep that is all, I think it rides and handles great just want a slightly more aggressive look. Sounds silly and if I can't find anything I'll leave it alone, I was just wondering if I'm the only one that would like the rear to look as aggressive as the front. Thanks
Maddogs700srx
Don't know if it would work or not, but you could try some drop down brackets from a 136" or 144" sled. I'd give a call to Mountain Performance and throw this question thier way.
Ding
Darn Tootin'
You can raise the snowflap, or cut it shorter but you will be roosting whoever is behind you. Ever follow a mountain sled on the trail?
98srx6
Ding said:You can raise the snowflap, or cut it shorter but you will be roosting whoever is behind you. Ever follow a mountain sled on the trail?
Yah, it sucks.
yamaholic22
it sucks following my buddy who has a ProX2 with the 1.25 inch track, that thing throws A LOT of garbage going down the trail, not to mention blowing up with 2,000 miles on it. Blown up Poo 800's, its an epidemic.
03viperguy
just leave it alone
yamaholic22
you could just shorten up your snowflap pretty easily, that would be much easier than lowering the suspension mounts in any way
VmaxSx600
Give maxdlx a pm, him and cb performance made some and they work with the proaction suspension
