yamyrider
I removed the chaincase to change bearings and now the brake wont hold pressure. I bleed them and they get hard but the minute I move the sled 50ft pressure is lost. It will hold pressure if it is parked but wont hold pressure after sled is running and moving. I am confused. 2003 Viper
Make sure the rotor is fully seated on the shaft & is straight. If not, it will wobble and push the brake open.
yamyrider
thanks edunn69, you were right. There was a wobble in the rotor which ended up being the top gear nut was lose. Put some blue lock tight and all works well. Except for a bog now.
