Engine light flashing
barkerman77
Madoc, Ontario, Canada
I Was out for a ride this weekend after about 70km I hit a good sized drift and bottomed out the sled. Right after that the engine light and the warning light were flashing. sled was running great as normal. I pulled off the trail shut it down and no fired it up again. It flashed twice like it always does when it first starts. Then It started into flashing. We counted 14 flashes without a break. the chart for the codes doesn't have that many. I pulled the power valve servo cover off and rolled the servo over. Wiggled all the plugs under the bar pads and the code stopped. I'm so confused as to why it did that.
I've been having an intermittent code for a thumb warmer resistor on my sled. Sometimes it will throw it sometimes it won't. Check the connector tabs inside the plastic connector. I had one where the contact would slide so when it was pushed together the wire got pushed out and the connection was bad even though it was plugged in.
