lil3incher
I just noticed while my engine was idling there is a ringing/small knocking noise coming from the engine, I removed the v-belt guard and turned the primary clutch back and forth with my hands and noticed there is a little knock there, Wondering if this is normal and if so how much noise should it be
Batwolf
Had the very same noise on my 600 twin, and created via same means of turning the primary back-n- forth... My engine is currently disassembled for other reasons, but I kept the issue in mind during disassembly and can't pin point; my crank is even out. Like you, I'm seeing what next step to take. Good luck man
