cylinder died momentarily
devinzz1
Newfoundland
Cylinder randomly died mid ride for a few minuets. Sounded like i burned it down and it was completely dead for about 40 seconds. Fairly high elevation. Sled ran flawlessly for the rest of day. Any ideas? Il upload gopro fotage tomorrow.
definitely not getting gas supply or stator is starting to go or needs a cleaning perhaps if there is rust on it.Check wiring also....if it happened once I bet it may happen again and maybe worse..investigate it.
New stator and cleaned flywheel last year. fairly new plugs/caps/coils. Actually that morning my choke did stick. I redid my wiring last year as well to make sure there was no rubbing and simplified it.
its weired how it cut out instantly like it didnt sput or slowly die like it was starved for fuel. If one coil went bad wouldnt there be no spark to all plugs? I think im just gona roll with it ahaha
