JeepJimmy
2001 yamaha vmax 700 red motor. Looking for a repair replacement connector for the coolant sensor? Any ideas? Cant find a part number...
See the link for part numbers and prices...
The connector can be disassembled to remove the terminals so you can solder the wires back to them. Pry the different colored tab lock to expose the finders that retain the terminal. Pry the finger away while pushing the terminal out the back side. Easier if you have someone holding the connector while you use one hand to pull the finger away while using the other to push the terminal out.
Use a paper clip - grind the end into a flat or point to use to engage the finders.
http://www.totallyamaha.net/forums/threads/98292-Thermosensor-connector/page2?highlight=ford+dealer
