1988 phazer motor
Ronny
Ste Anne de kent new Brunswick Canada
Hi I have a 88 phazer and the motor blow so I got another motor but there is 2 Xtra
Wires on the other one. Is it possible to change the charge system from one motor to a another if yes I have to cut some slive to install my fan housing and what about timing
help thank you Ronny :o|
Yes, you have to change the stator, flywheel and fan housing. Might not have to change the fan housing, but it would be a cleaner swap, not having the pick up coil in there.
