Warning codes on a 2001 700sxr...
sleddineinar
Ramsey Minnesota, United States
I got a pdf manual and it shows the code patterns, but not what the flashes are telling you. Last weekend I would get warning code a couple times for about 20 minutes each, right after filling up, I got a code, it was a long flash then 2 short ones, then a bit of a pause and it repeats. Anyone know what that is? I put 390 miles on it and it ran great, but I hate not knowing what the code was trying to tell me...
OK, I found the link in the Tech Section that not only described the codes, but also said what the code was telling you. But I still don't see the code, that was being displayed. It was a Long flash, long pause, then 2 short flashes. The nearest code I saw in the Link was a Long flash & 3 short flashes, but mine only showed 2 short flashes after the long flash. Does anybody know what that is. Also it only showed up after stopping for gas at the same station. I always buy 91 non-oxy. This was actual station with below ground tanks.
