red9268
I have two Enticer 300 Special Twins, a 79 and 80. Both are stock and I am planning on racing the 79. It runs good but has a little bog on the top end. When held to the bars it starts to fall off after about 7-8 seconds. Looking for ideas, suggestions. I believe the clutch springs are original. I am also looking for an economical clutch kit that I could do. Any help would be appreciated. Thanks- Kevin
Hold it to the bar for about 15-20 seconds and kill motor and check plugs. You still have snow?
red9268
No snow around me. Thanks
Have you made sure the carbs are cleaned really good? Check the clutch rollers and bushings ... maybe its not allowing it to shift out...or the belt is getting sucked in.
red9268
Thanks MrSled. Will be adding that to the list. The belt is definitely not new.
